bespoke thumb brakes |
Post Reply |
Author | |
zxrjohn14
Racer Joined: 15 December 2011 Status: Offline Points: 663 |
Posted: 21 October 2017 at 16:59 |
following on from the advert in the wrong section (D'oh), I have know perfected the thumb brakes.
I can knock a bespoke thumb brake up for £150 plus post in aluminium, this would include, a small master cylinder (not brembo!!), up to 2 meters of brake line and 2 straight banjo's. it would be up to you to fit it from there. if you want it any different, let me know and i'll do them. if you wanted to use your own master cylinder or supply your own line etc, let me know and we'll sort the price out A deposit of £30 per master cylinder paid by paypal for commitment reasons and you can pay goods and services if you want. you will have to let me know what clamp size, and please make sure that it is taken in the correct place of the fork leg as many legs taper below the bar clamp, how much line you want and your address, all through paypal please so i can keep track of stuff. i have Goodridge braided line with black cover on the way and small 14mm bore master cylinders on the way too. one of the images shows a brembo, this is just to make sure that different master cylinders will work, but it would be up to you to space them to correct position for working if using your own master cylinder this is just a hobby to keep me occupied at weekends and things will be made to order, so 7-10 day turnaround is to be expected. if you want to get in touch, please pm me and i'll send you my number edit: i can't get images up automatically
Edited by zxrjohn14 - 21 October 2017 at 17:02 |
anubis
fast Group Joined: 17 May 2016 Location: Ayrshire Status: Offline Points: 210 |
ooh I like that, nice work.
What length is that lever? I'm not sure it can be done but could this be connected in such a way that allows the foot lever to remain operational? (without buying a dual master from beringer that costs a fortune)
zxrjohn14
Thank you, sir. The length of the lever is 100mm from the pivot, but could be made longrr or shorter should someone wish. It just means I'd have to redraw and do a program for it. There is a way to leave the foot lever on too, I've not dabbled with it myself, but know of it being done, and that's to connect the thumb brake line to where the reservoir is. This would involve tapping the bit or making something to adapt to take the banjo instead of the reservoir on the foot master cylinder. The banjo bolt would need a bleed nipple on it so it could be bled in two stages, thumb brake then foot lever. Edited by zxrjohn14 - 21 October 2017 at 17:46 |
anubis
I'm definitely interested if you could do a 110mm lever with a 43mm clamp?
Do you think it could be done by connecting the line from the thumb master to the caliper itself and have a two MC system going or is that daft? I don't have an engineering background but lots of "bright" ideas I'm only asking this because me & the mrs will be sharing the bike and I'm not sure if she'll take to a thumb brake idea. Or at least have the option on the foot brake til she's used to it
zxrjohn14
Hmm interesting.
I'm thinking the pressure would go through the equalization port and up the foot brake reservoir as this is what it's designed to do when the fluid expands to stop locking the brake on. I may do a few tests regarding this. I can do one for you no problem. Pm me and I'll send payment details. |
anubis
Fair point. I might just fit it and make her adjust
Gizago
Admin Group Joined: 31 March 2014 Location: Brighton Status: Offline Points: 2130 |
I’m sure I’ve seen a valve somewhere that fits on the m/c to let you use both, I’ll see if I can find it.
www.moto-racespares.com
Use discount TDR10 at checkout |
anubis
Great, thanks
Jaymo
Instructor Joined: 10 April 2013 Location: Norwich Status: Offline Points: 2328 |
Yep. GPtech do one- Poss avail through demon tweeks. I didn’t bother and just used a single line only |
zxrjohn14
latest verion
anubis
^^^ that's mine, now I'm like this
(just realised pic doesn't show up on phone, oops) Edited by anubis - 29 October 2017 at 19:35 |
anubis
Got mine!
These look cracking, really nicely made. I'm just waiting for a junction valve before I connect it all up. If you're thinking about one of these then give John a shout, you won't be disappointed
carlinmidarlin
Starter Joined: 07 December 2015 Location: Wigan Status: Offline Points: 18 |
Hi , we're have you got your junction valve from mate , I'll be needing 1 real soon
Cheers mick |
anubis
Thanks(1)
I ordered it from here
http://www.hoheydesigns.com/store/index.php?main_page=product_info&cPath=10&products_id=199 Few things to bear in mind - They don't respond to emails They take about two weeks to process the order I was in the process of cancelling the order when I received tracking info and it's now in the UK Other places are available like demon tweeks, they can get it from GPtech for £67 but they also order from the US with no lead time HEL performance sent me one that could work but you have to tap it into the master cylinder, I couldn't make that work. Bottom line if I was doing it again I'd just order through demon tweeks, at least then I'd have a point of contact in the UK Hope this helps |
slimjim
Instructor Joined: 28 January 2009 Location: Hertfordshire Status: Offline Points: 2256 |
This looks good!
I've been thinking about a thumb brake for my r6 fir a while. |
anubis
So this arrived today. For all it is I reckon I got my ass handed to me regarding cost+delivery+customs If you're thinking of going down this route, just go through demon tweeks for the GPtech one, this one wasn't worth the hassle - lesson learned |
yzchris
Starter Joined: 08 November 2015 Location: Cork Status: Offline Points: 26 |
Hi, just wondering are you still making these?
Post Reply | |
Forum Jump | Forum Permissions You cannot post new topics in this forum You cannot reply to topics in this forum You cannot delete your posts in this forum You cannot edit your posts in this forum You cannot create polls in this forum You cannot vote in polls in this forum |
