GSXR 10000 2017 Onwards Keyless ignition |
Post Reply |
Author | |
Eyespy
Instructor Joined: 30 September 2011 Location: Quiet Essex Status: Offline Points: 2508 |
Posted: 03 April 2021 at 12:40 |
THIS WILL ONLY WORK IF YOU HAVE DISABLED THE IMMOBILISER VIA AN ECU FLASH OR EQUIVALENT Plug and play keyless ignition switch... Prewired with OEM connector and ideal if you want to replace top yoke with race item or just remove the bulky key barrel... Unplug and remove the key barrel, plug in switch (you cannot get it wrong as it only fits in one connector that is green) and connect earth lead to suitable location. The switch will then power on bike like the key does and the tip of the switch lights up to show it is on. To locate securely it requires a 12mm hole drilled somewhere suitable, below the clocks can work. Instructions available on request. £35 delivered to mainland UK One currently available, more being made. PM or call 07841 459767 THIS WILL ONLY WORK IF YOU HAVE DISABLED THE IMMOBILISER VIA AN ECU FLASH OR EQUIVALENT
Post Reply | |
Forum Jump | Forum Permissions You cannot post new topics in this forum You cannot reply to topics in this forum You cannot delete your posts in this forum You cannot edit your posts in this forum You cannot create polls in this forum You cannot vote in polls in this forum |
