Lots of goodies 08 blade. |
Post Reply |
Author | ||
Lifeofriley
intermediates Joined: 12 April 2018 Location: Essex uk Status: Offline Points: 165 |
Posted: 14 May 2019 at 06:43 |
Hi guys I'm breaking my 08 blade track bike here's a list of some parts which I will add to. Pictures upon request via email. Bike can be sold as a hole for £4.5k lots of spares etc. And runs perfectly just needs some fairings and clocks due to off.
Hel race style front brake lines £30 Translogic is4 quickshifter with rod £300 Online steering damper £220 Mss clip ons and clamps £60 Unbranded clip ons and clamps £40 HRC rear subframe £100 Piperwerx 400mm exhaust with hanger and baffle, slightly damaged bit can be repaired.£70 HRC kit ECU and loom with relays/tip sensor all ready to work £700 Promach rearsets £200 Healtech gear indicator for HRC loom £65 Forks with ktech DDS internals £800 Ktech DDS pro rear shock with remote adjuster. £700 Rental 520 did chain with sprockets £50 Spare wheels £250 Spare wheels with comp k tyres only done one day, and cush drive etc ££370 Frame?? Engine on 8000k runs perfectly with 166bhp recent Dyno to prove it.?? Sigma slipper clutch with clutch plates £400 GB racing bullet sliders one slider needs replacing £30 Radiator guard £30 Active quick action throttle, gravel rashed.£20 HRC rectifier bracket £25 Brembos RCS gravel rashed on lever.£130 Brembos hpk front discs lots of meat on them.£300 Rear paddock stand hooks.£15 Harris rear paddock stand. eBay yoke style front paddock stand. Spare levers. Samco coolant hoses/red £50 Rear seat unit,slightly damaged. Lighttech fuel cap £50 Belly pan used. Front fender red Front fender black Tank cover slightly damaged. And all standard parts like calipers,tank,rad etc Postage added on top. Edited by Lifeofriley - 19 May 2019 at 11:33 |
Sarn9
Starter Joined: 10 May 2019 Location: Stockport Status: Offline Points: 2 |
Is the gear indicator a plug and play item or does it require the wheel speed indicator |
Lifeofriley
It hard wires into the loom with 4 wires. It's the latest universal model.
zk4shaun
fast Group Joined: 02 June 2010 Location: Kent Status: Offline Points: 323 |
Does it make a full set of track fairings?? Any pictures? Im only Kent so could collect
Lifeofriley
Bump prices added
nozdog
Instructor Joined: 25 January 2012 Location: Kent Status: Offline Points: 1071 |
Hi there is the black front fender still for sale and how much posted do you want for it cheers Alex
Lifeofriley
Hi mate still for sale but it's gravel rashed let me know if your still interested and I will send you pics over email. Cheers j |
nozdog
Ok no worries by the time I buy it and get it repainted not really worth it but thanks for letting me know
Lifeofriley
Thanks(1)
No worries at all pal.
Post Reply | |
Forum Jump | Forum Permissions You cannot post new topics in this forum You cannot reply to topics in this forum You cannot delete your posts in this forum You cannot edit your posts in this forum You cannot create polls in this forum You cannot vote in polls in this forum |
