  New Posts New Posts RSS Feed - Lots of goodies 08 blade.
Lifeofriley View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lifeofriley Quote  Post ReplyReply Direct Link To This Post Topic: Lots of goodies 08 blade.
    Posted: 14 May 2019 at 06:43
Hi guys I'm breaking my 08 blade track bike here's a list of some parts which I will add to. Pictures upon request via email. Bike can be sold as a hole for £4.5k lots of spares etc. And runs perfectly just needs some fairings and clocks due to off.
Hel race style front brake lines £30
Translogic is4 quickshifter with rod £300
Online steering damper £220
Mss clip ons and clamps £60
Unbranded clip ons and clamps £40
HRC rear subframe £100
Piperwerx 400mm exhaust with hanger and baffle, slightly damaged bit can be repaired.£70
HRC kit ECU and loom with relays/tip sensor all ready to work £700
Promach rearsets £200
Healtech gear indicator for HRC loom £65
Forks with ktech DDS internals £800
Ktech DDS pro rear shock with remote adjuster. £700
Rental 520 did chain with sprockets £50
Spare wheels £250
Spare wheels with comp k tyres only done one day, and cush drive etc ££370
Frame??
Engine on 8000k runs perfectly with 166bhp recent Dyno to prove it.??
Sigma slipper clutch with clutch plates £400
GB racing bullet sliders one slider needs replacing £30
Radiator guard £30
Active quick action throttle, gravel rashed.£20
HRC rectifier bracket £25
Brembos RCS gravel rashed on lever.£130
Brembos hpk front discs lots of meat on them.£300
Rear paddock stand hooks.£15
Harris rear paddock stand.
eBay yoke style front paddock stand.
Spare levers.
Samco coolant hoses/red £50
Rear seat unit,slightly damaged.
Lighttech fuel cap £50
Belly pan used.
Front fender red
Front fender black
Tank cover slightly damaged.
And all standard parts like calipers,tank,rad etc
Postage added on top.
Edited by Lifeofriley - 19 May 2019 at 11:33
Sarn9 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sarn9 Quote  Post ReplyReply Direct Link To This Post Posted: 16 May 2019 at 13:00
Is the gear indicator a plug and play item or does it require the wheel speed indicator
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lifeofriley Quote  Post ReplyReply Direct Link To This Post Posted: 16 May 2019 at 13:43
It hard wires into the loom with 4 wires. It's the latest universal model.
zk4shaun View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote zk4shaun Quote  Post ReplyReply Direct Link To This Post Posted: 16 May 2019 at 14:18
Does it make a full set of track fairings?? Any pictures? Im only Kent so could collect
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lifeofriley Quote  Post ReplyReply Direct Link To This Post Posted: 19 May 2019 at 11:34
Bump prices added
nozdog View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote nozdog Quote  Post ReplyReply Direct Link To This Post Posted: 21 May 2019 at 19:25
Hi there is the black front fender still for sale and how much posted do you want for it cheers Alex
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lifeofriley Quote  Post ReplyReply Direct Link To This Post Posted: 21 May 2019 at 19:55
Hi mate still for sale but it's gravel rashed let me know if your still interested and I will send you pics over email. Cheers j
Post Options Post Options   Thanks (0) Thanks(0)   Quote nozdog Quote  Post ReplyReply Direct Link To This Post Posted: 21 May 2019 at 22:13
Ok no worries by the time I buy it and get it repainted not really worth it but thanks for letting me know
Post Options Post Options   Thanks (1) Thanks(1)   Quote Lifeofriley Quote  Post ReplyReply Direct Link To This Post Posted: 21 May 2019 at 22:14
No worries at all pal.
This page was generated in 0.172 seconds.
