R1 2cr parts |
Post Reply |
Author | |
quarrybends
Instructor Joined: 08 June 2012 Location: yorkshire Status: Offline Points: 2917 |
Posted: 08 November 2019 at 11:29 |
2 x used frames both factory blanks, 1 standard, 1 superbike braced frame £1495 and 1695
New k and n air filter £50 used standard quickshifter £100 standard master cylinder without the blade as new £60 standard bars £60 USA ignition Switch with key £75 (no need for antenna with an ecu flash but retains security of the lock) standard bellmouths £40 might be interested in a deal against other r1 stuff, aftermarket bars, subframe, wheels etc etc based rotherham s.yorks |
quarrybends
quarrybends
sold
Edited by quarrybends - 08 December 2019 at 09:53 |
quarrybends
sold
Edited by quarrybends - 08 December 2019 at 09:54 |
quarrybends
Calipers as new £175
quarrybends
quarrybends
Standard wheels in black almost unmarked- 1 stone chip from memory £1000 without discs or wheel speed sensor triggers but does come with sprocket carrier and cush drive
Edited by quarrybends - 13 December 2019 at 14:54 |
quarrybends
quarrybends
kit ecu and loom bargain 800
quarrybends
New crc bodywork 2015/2018
Nosecone, side panels, bellypan and dzus fasteners £325 - only ever test fitted tot the bike |
quarrybends
remaining:
standard shock tss rear subframe rad fan x 1 usa ignition switch with key All other parts sold |
Post Reply | |
Forum Jump | Forum Permissions You cannot post new topics in this forum You cannot reply to topics in this forum You cannot delete your posts in this forum You cannot edit your posts in this forum You cannot create polls in this forum You cannot vote in polls in this forum |
