  New Posts New Posts RSS Feed - R1 2cr parts
R1 2cr parts
quarrybends View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote quarrybends Quote  Post ReplyReply Direct Link To This Post Topic: R1 2cr parts
    Posted: 08 November 2019 at 11:29
2 x used frames both factory blanks, 1 standard, 1 superbike braced frame £1495 and 1695
New k and n air filter £50
used standard quickshifter £100
standard master cylinder without the blade as new £60
standard bars £60
USA ignition Switch with key £75 (no need for antenna with an ecu flash but retains security of the lock)
standard bellmouths £40
might be interested in a deal against other r1 stuff, aftermarket bars, subframe, wheels etc etc
based rotherham s.yorks
Post Options Post Options   Thanks (0) Thanks(0)   Quote quarrybends Quote  Post ReplyReply Direct Link To This Post Posted: 08 November 2019 at 19:48
New k and n air filter £50 SOLD
standard bars £60
Post Options Post Options   Thanks (0) Thanks(0)   Quote quarrybends Quote  Post ReplyReply Direct Link To This Post Posted: 04 December 2019 at 09:01
sold
Edited by quarrybends - 08 December 2019 at 09:53
Post Options Post Options   Thanks (0) Thanks(0)   Quote quarrybends Quote  Post ReplyReply Direct Link To This Post Posted: 05 December 2019 at 07:05
sold
Edited by quarrybends - 08 December 2019 at 09:54
Post Options Post Options   Thanks (0) Thanks(0)   Quote quarrybends Quote  Post ReplyReply Direct Link To This Post Posted: 07 December 2019 at 14:53
Calipers as new £175
Post Options Post Options   Thanks (0) Thanks(0)   Quote quarrybends Quote  Post ReplyReply Direct Link To This Post Posted: 10 December 2019 at 18:52
2 x used frames both factory blanks, 1 standard, 1 superbike braced frame is now sold £1250 for the stock chasis
New k and n air filter £50 sold
standard master cylinder without the blade as new £60 sold
standard bars £60
Post Options Post Options   Thanks (0) Thanks(0)   Quote quarrybends Quote  Post ReplyReply Direct Link To This Post Posted: 13 December 2019 at 14:53
Standard wheels in black almost unmarked- 1 stone chip from memory £1000 without discs or wheel speed sensor triggers but does come with sprocket carrier and cush drive
Edited by quarrybends - 13 December 2019 at 14:54
Post Options Post Options   Thanks (0) Thanks(0)   Quote quarrybends Quote  Post ReplyReply Direct Link To This Post Posted: 20 December 2019 at 08:15
1 x used frame factory blank, 1 standard 1295
New k and n air filter sold
used standard quickshifter sold
standard master cylinder without the blade as new sold
standard bars £60
Post Options Post Options   Thanks (0) Thanks(0)   Quote quarrybends Quote  Post ReplyReply Direct Link To This Post Posted: 20 December 2019 at 08:16
kit ecu and loom bargain 800
Post Options Post Options   Thanks (0) Thanks(0)   Quote quarrybends Quote  Post ReplyReply Direct Link To This Post Posted: 06 January 2020 at 19:29
New crc bodywork 2015/2018
Nosecone, side panels, bellypan and dzus fasteners £325 - only ever test fitted tot the bike
Post Options Post Options   Thanks (0) Thanks(0)   Quote quarrybends Quote  Post ReplyReply Direct Link To This Post Posted: 02 March 2020 at 12:10
remaining:
standard shock
tss rear subframe
rad fan x 1
usa ignition switch with key
All other parts sold
This page was generated in 0.156 seconds.
