  New Posts New Posts RSS Feed - R6 parts mainly pre injection  5eb - sl - clearout
 Post Reply Post Reply Page  123>
2stop View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 2stop Quote  Post ReplyReply Direct Link To This Post Topic: R6 parts mainly pre injection 5eb - sl - clearout
    Posted: 30 November 2014 at 20:06
As the bikes sold i,m now realising how many spare i,ve accrued over the last 4 years .
most of them not used by me but some have .
My bike was 5eb (carbs) but i know some parts do fit the injected 5sl - try Ronayers.com online fiche for compatability.
click on the link below for pics . i,ll put them on the bay in a couple a weeks or so all prices + post/ courier + offers .But would prefer collection(near peterborough) on larger items as its a ballache.
or p.m me if any other bits u require i,ll see what i have .
cheers .
Pair of forks stock forks , unused by me but look straight in the bike
few marks here and there        £60    - SOLD
R6 5eb pair of yokes top , bottom and steer stem ,unused by me
bought with some spares . usual marks        £30.00 - SOLD
Bottom yoke and steer stem , unused by me , needs a clean                                     £15
Rear subframes 3 off 1 supposedly tidy spar bought from ebay is nice and
straight but the tank bolt wont go in but can cable tie on .
1 bit bent side to side but plenty serviceable for trackdays .
1 started to chop for mods but never used and is bit bent  - all 3                               £55     -  SOLD
Factory pro ignition advancer (for R6 5eb , carbs) NEW -still in box , never got it
on the bike . these weren,t available new last time i looked..                                     £45      -  SOLD
swingarms x 2 - unused by me but came with some spares both have a few
marks 1 has a small dent (near link pipe)        £10 each
stock rear shock , unused by me with link plates , would clean up                             £15     - SOLD
Generator and cover complete bought and kept as a track spare
never used by me , few marks        £35
stator , pick up , timing cover and pick up complete , with diy reinforced
cover and diy carbon slider . unused spare        £24     - SOLD
Full titanium system all on spring hooks apart from end can by ring clamp.
End can is blue flame complete with baffle and retaining circlip.                        - END CAN  - SOLD
can has a few scuffs , system tidy apart from small dent near swingarm on
the inner face , not visible on bike.
Large part of can is 16" long - had a 2bhp gain on mine with this with a soft
tune motor        £120 -  SYSTEM
        SOLD
Scorpion slip on stainless steel end can, tidy with few marks -
with removable baffle , ideal quiet can
Its 51.5mm - 52mm  internal diameter approx ,where i slips on the link .
Can length approx 18"        £45  - SOLD
Micron end can and link pipe , the can fits the link with a ring clamp it
fits onto standard headers . (really needs a new ring clamp headers end)
its 51.5mm - 52mm  internal diameter approx , where it slips on the link
can length approx 18" 5/8 , few marks , would clean up .
marked not for road use , no baffle        £50   - SOLD
High level link pipe only (fits standard headers) in stainless with heatshield
never did get it fitted . no brackets either but google mig hi level
exhaust i think .        £15
CDI , igniter box , standard spare , unused by me                                                      £35
coil sticks x3 unused track spares        £14   - SOLD
carbs with velocity stacks and inlet maniold rubbers , bought as spares
ran up once on the bike .        £86
Harris front screen brace (fits stock clocks) - repaired , trackday spare                      £24       -  SOLD
front sprocket 520 renthal + 2 lock washers 1 new , 1 old .14 tooth.
(also fits few other check in pic.)        £12
Rear sprockets 520  Renthal lightweight x2 - 1 50 tooth , 1 - 48 tooth
+ sprocket carrier for 5eb        £45
Double bubble screen clear , few marks ok track spare                                             £14         - SOLD
standard clocks , bought off here never used , looks a heat bubble on
the exterior see pic , but tidy enough for t,days .
untested by me but bought as working        £12     - SOLD
Clip ons , standard fit 5eb and 5sl i think . never used by me , bit marked
up but o.k for t,days        £15
Clutch - complete with tidy cover.        £40        -  SOLD
Clutch basket        £20
clutch lever , standard (might need to press the brass bush out and swap from
from your exisitng lever)  few marks , trackday spare                                                £6          -SOLD
front axle / spindle and spacers , would clean up                                                      £8
complete standard gearbox still in the old casings ,                                                  £50??
crank / rods still in old casings        £37 ??
pistons  4 all used        £10
old casings buggered (cylinder cracks) and no head i,m afraid , cams are there
though.
K and N air filter , no rubber gasket ...... needs a service clean                                £5
stock headers , retaining rings are real furry tatty ! but could be cleaned
up for track spares , pipes shabby but would clean up                                            £10
Rear Sets - Cheapo rubbish !! that came on the bike ,i had to shim the shifter
(no bearing) but complete with heel plates and lever so i kept as handy complete
spares in my box  - also fitted with Walter moto lift plates (these are handy to
mount rearsets or stock pegs frther back / up)                                                       £30
Spare pro mach rear set lift plates        £10 - SOLD
oil pump, relief valve , pick up and ancillaries                                                          £10 -SOLD
standard sump with level sensor - drain plug needs helicoil !!                               £8
starter motor        £5   -SOLD
water pump and hoses        £8   -SOLD
also realised i,ve got 2 front mudguard        -SOLD
pick up on larger items .
cheers.
Edited by 2stop - 03 December 2017 at 12:24
sam.nicholson View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote sam.nicholson Quote  Post ReplyReply Direct Link To This Post Posted: 01 December 2014 at 09:37
Hi,
Would you take £24 including P&P for the Harris front screen brace?
I'm also interested in the ignition advancer. Although not Factory Pro they sell for £19 on e-bay, they do exactly the same job, so £45 sounds a bit steep really.
Would you do both delivered for £35?
Thanks
Sam
Post Options Post Options   Thanks (0) Thanks(0)   Quote 2stop Quote  Post ReplyReply Direct Link To This Post Posted: 01 December 2014 at 18:58
where u based let me know p.m
Post Options Post Options   Thanks (0) Thanks(0)   Quote 2stop Quote  Post ReplyReply Direct Link To This Post Posted: 01 December 2014 at 19:23
just had a look , does seem they are going for 20quid ,on the bay, it was bit more
when i looked but that was 18 months ago ,so fair enough , hows £40 delivered ?
koreanbaz View Drop Down
TDR No.1 Grass
Post Options Post Options   Thanks (0) Thanks(0)   Quote koreanbaz Quote  Post ReplyReply Direct Link To This Post Posted: 01 December 2014 at 19:37
Can you post a swingarm to Stockport please?
Myhermes takes days. But cheap as chips.
For my project 👍
Life is not a trial run!
Post Options Post Options   Thanks (0) Thanks(0)   Quote 2stop Quote  Post ReplyReply Direct Link To This Post Posted: 02 December 2014 at 07:17
For my project 👍
Send ur address det,s Baz . (p.m)
Have a look at pics , which u want or do u want me to sen
d both and u can choose .
TDR No.1 Grass
Post Options Post Options   Thanks (0) Thanks(0)   Quote koreanbaz Quote  Post ReplyReply Direct Link To This Post Posted: 02 December 2014 at 07:54
For my project 👍
pm sent
thumbsup
Post Options Post Options   Thanks (0) Thanks(0)   Quote 2stop Quote  Post ReplyReply Direct Link To This Post Posted: 02 December 2014 at 21:07
I may be in Grantham sat a.m now briefly.
With some parts if this helps anyone else interested in anything.
Cheers.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 2stop Quote  Post ReplyReply Direct Link To This Post Posted: 05 December 2014 at 13:26
Cheers.
Confirmed I will be there sat morn if this helps anyone else.
P.m on here .cheers.
Edited by 2stop - 05 December 2014 at 13:27
mozzer1962 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mozzer1962 Quote  Post ReplyReply Direct Link To This Post Posted: 06 December 2014 at 15:55
hi have you still got the stator pick up cover
if so how much posted . mozzer
Post Options Post Options   Thanks (0) Thanks(0)   Quote 2stop Quote  Post ReplyReply Direct Link To This Post Posted: 06 December 2014 at 16:26
stator pickup and cover £24 as listed above -+ postage £4.00
Post Options Post Options   Thanks (0) Thanks(0)   Quote 2stop Quote  Post ReplyReply Direct Link To This Post Posted: 08 December 2014 at 18:56
Clutch and cover , ignition advancer and front fairing stay sold.
List ammended -see above-..
Clutch basket still available .
P.m me for anything in case have , cheers.
whalefish View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote whalefish Quote  Post ReplyReply Direct Link To This Post Posted: 12 January 2015 at 21:57
Hi, do you still have the titanium system?
Post Options Post Options   Thanks (0) Thanks(0)   Quote 2stop Quote  Post ReplyReply Direct Link To This Post Posted: 13 January 2015 at 20:10
Yes mate supposed to be listing the lot on eBay at end of month before I get an earbashing.
Click online gallery link above to view parts.
Post Options Post Options   Thanks (0) Thanks(0)   Quote whalefish Quote  Post ReplyReply Direct Link To This Post Posted: 14 January 2015 at 08:54
i'll have it off you if you still have it at the end of the month, im skint untill pay day. my phone number is 07738604763 if you want to give me a call
Post Options Post Options   Thanks (0) Thanks(0)   Quote 2stop Quote  Post ReplyReply Direct Link To This Post Posted: 14 January 2015 at 18:28
O.k whalefish won,t go on eBay till end month .
U can send me a private message on here if u like .?
I,ll keep a note of ur no.
Roughly where u based ?
Post Options Post Options   Thanks (0) Thanks(0)   Quote 2stop Quote  Post ReplyReply Direct Link To This Post Posted: 13 February 2015 at 08:32
Still got most of these bits .
Not had time to eBay it yet but trying to put them on next week.
Go to the top of this post for the online gallery of all the bits n pieces .
Or pm me for anyrhing in case I have it.
Cheers.
Wowey View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Wowey Quote  Post ReplyReply Direct Link To This Post Posted: 17 February 2015 at 12:22
Messaged you about the end can
Post Options Post Options   Thanks (0) Thanks(0)   Quote 2stop Quote  Post ReplyReply Direct Link To This Post Posted: 17 February 2015 at 18:28
Replied , deposit taken on that can . Sorry.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 2stop Quote  Post ReplyReply Direct Link To This Post Posted: 17 February 2015 at 18:29
Deposit taken on scorpion can.
Boom34 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Boom34 Quote  Post ReplyReply Direct Link To This Post Posted: 17 February 2015 at 22:59
What make is the full titanium system?
Post Options Post Options   Thanks (0) Thanks(0)   Quote 2stop Quote  Post ReplyReply Direct Link To This Post Posted: 18 February 2015 at 08:55
That is the million dollar question ! Showed a few people , no one seems to know (no stamping) but has a blue flame can fitted with removable baffle.
(did u view pics?)
Ninjaboy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ninjaboy Quote  Post ReplyReply Direct Link To This Post Posted: 18 February 2015 at 21:34
Still got the rearsets bud?
Post Options Post Options   Thanks (0) Thanks(0)   Quote 2stop Quote  Post ReplyReply Direct Link To This Post Posted: 19 February 2015 at 08:33
Still got them , shocking quality and I would only say use as spares . Saying that I did shim them and run them on the bike with no probs until I got some tidy promachs .
Did u see the lift / mount plates they are seperate they will lift and move back from stock position slightly .
These are o.k , Walter moto I think .
Should be in pics above if not pm and I will send pic.
markyw4655 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote markyw4655 Quote  Post ReplyReply Direct Link To This Post Posted: 04 March 2015 at 22:23
do you still have the front fenders? how much do you want for them?
Post Options Post Options   Thanks (0) Thanks(0)   Quote 2stop Quote  Post ReplyReply Direct Link To This Post Posted: 05 March 2015 at 07:30
Still got em I will p.m u pics and prices 2nite when I get in.
Post Options Post Options   Thanks (0) Thanks(0)   Quote markyw4655 Quote  Post ReplyReply Direct Link To This Post Posted: 05 March 2015 at 08:46
Nice one..
Post Options Post Options   Thanks (0) Thanks(0)   Quote 2stop Quote  Post ReplyReply Direct Link To This Post Posted: 05 March 2015 at 19:21
p.m with fender pics sent to markyw .
Wurley View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Wurley Quote  Post ReplyReply Direct Link To This Post Posted: 19 March 2015 at 12:07
Hi there do you still have the carbs & would you accept £50 for them ? ? ?
Post Options Post Options   Thanks (0) Thanks(0)   Quote 2stop Quote  Post ReplyReply Direct Link To This Post Posted: 19 March 2015 at 20:40
Pm sent wurley
ctowers1 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ctowers1 Quote  Post ReplyReply Direct Link To This Post Posted: 20 March 2015 at 16:33
PM coming
Post Options Post Options   Thanks (0) Thanks(0)   Quote 2stop Quote  Post ReplyReply Direct Link To This Post Posted: 23 March 2015 at 06:47
Clutch lever , stator pick up , screen and subframes reserved for ctowers , will update list later.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 2stop Quote  Post ReplyReply Direct Link To This Post Posted: 31 March 2015 at 19:47
These now sold and main parts list with items sold updated at the top of the post.
Ti system now reduced £120 as has no end can with it as that was sold seperately ..
also found a spare nosecone the other week , has had an "ear" repaired but plenty serviceable painted and lacquered white with red stripe .
Post Options Post Options   Thanks (0) Thanks(0)   Quote 2stop Quote  Post ReplyReply Direct Link To This Post Posted: 10 May 2015 at 09:38
Still got lotta bits , see above .
The micron can and link still available and carbs .
Also got a clutch basket , no cover.
Bttt for gallery pics or ask in case it was a late clear out find and not in the list , cheers.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 2stop Quote  Post ReplyReply Direct Link To This Post Posted: 22 May 2015 at 19:44
[QUOTE=2stop] Still got lotta bits , see above .
Not in the pics.
Still got forks and yokes, micron can and link , to system (the micron will slip on it if need both) swingarms, stock shock, generator and cover, igniter box / ecu , hi level link pipe, cheapo rear sets , 2 sets of peg lift plates , stock clip ons ,sprockets 520 , front 14t , rears 48 , 50 and rear carrier, stock clocks , front axle and spacers , sidestand. Gearbox , crank n rods , pistons.
All collect near Peterborough or post (see top if thread) or poss take to next t'day .
Converting into newer r6 parts l.o.l..
Fandoracing View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fandoracing Quote  Post ReplyReply Direct Link To This Post Posted: 22 May 2015 at 20:53
Does the 5eb shock fit the 5sl? Tried using that Ron site but not sure
#nailit
Post Options Post Options   Thanks (0) Thanks(0)   Quote 2stop Quote  Post ReplyReply Direct Link To This Post Posted: 23 May 2015 at 08:06
L.o.l me too , not sure on that mate but the 5sl is a different.swingarm.
Out of interest (no good to u I know) the r6 06 2c0 model and r6 13s (09 to current) are the same.
Try putting a post on here , tony parkitt or Colin 100% suspension would be able to tell you.
R6_lad View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote R6_lad Quote  Post ReplyReply Direct Link To This Post Posted: 23 May 2015 at 12:31
Do the rear set lift plates just work with the standard rear sets? Do you know how much they raise and pull back the rear sets? I'll take a set of you as mine could do with going up and back a little.
Cheers,
Kam
Post Options Post Options   Thanks (0) Thanks(0)   Quote 2stop Quote  Post ReplyReply Direct Link To This Post Posted: 23 May 2015 at 18:07
Think they would work with standard rsets but I had aftermarkets I will have a look 2moro n post back on here.
Post Options Post Options   Thanks (0) Thanks(0)   Quote R6_lad Quote  Post ReplyReply Direct Link To This Post Posted: 23 May 2015 at 19:15
Thanks mate.
This page was generated in 0.094 seconds.
