ZX10R Track bike with V5 |
Post Reply |
Author | |
ellz
Racer Joined: 21 August 2011 Location: Warwick Status: Offline Points: 582 |
Posted: 02 May 2015 at 19:42 |
Hi all, for sale is my good old trusty steed, had it for about 2 years now, and as you can see with the amount of tyres I've collected I was going to keep her for a little while longer. Only reason for selling now is to buy a newer 2011 onwards ZX10R, so if anyone wants a part ex for one of those let me know.
I'll probably miss some stuff out but here it goes Specs are as follows:
Kawasaki ZX10r C1 Track, Race & daylight road bike (This bike does not have lights) The bike has been well maintained - (oil & filter change every 4 trackdays) and has a huge spec, I bought the bike 2 years ago with 5399 miles on the clock, it now has 6167 miles. 2005 Blueprinted motor (standard spec - 159BHP tested with exhaust baffle fitted ) Stage 1 tuned & custom rolling road map, DynoJet PCIII ECU Arrow full system with Akrapovic road legal 60mm pipe repacked recently & has always passed me at track days with baffle (included) K&N Filter Dynojet Quickshifter Dymag 16.5” 5 Spoke Magnesium 2005 BSB wheels Braking front & rear discs Ktec fork revalve, Ohlins 10% springs Ohlins PRC Shock Brembo 19x20 Brake Master Cylinder, factory machined slotted lever, left hand remote span adjuster & Harris billet reservoir Nissin ZZR1400 brake caliper upgrade Goodridge brake lines AP Racing 2 piston mini anti lock rear Caliper & Harris bracket - SOLD separately stand item put on. HRC overflow bottles for coolant & fuel Quick release Harris Carbon fuel cap & matching ‘Quick-Fill’ refueling tank Fairing Quick release fittings throughout including stainless Pro-bolt stainless Dzus fittings Mix of Talon & Renthal spare sprockets (for both sets of wheels) & Tsubaki 520 chain, geared down front sprocket (-1t) Standard Slipper Clutch as used in BSB 2005/6 Sato Rearsets, reverse or road shift Ohlins side Factory BSB mounted Steering Damper with quick release fittings NRC heavy duty ignition engine cover B1H ZX6r rear shock linkage conversion Harris exhaust hanger, lockwired with titanium drilled bolts Becon Laptimer R&G crash protection throughout (right hand lever bung missing, fell off at last track day see photo) Carbon frame protectors Rear paddock stand lifters & Harris paddock stand Lock-wired throughout, sump, filler, brakes, exhaust Factory titanium chain hanger Titanium Axle nut, Titanuim drilled brake hanger bolts, pad pins, banjo bolts & fork pinch bolts Quick release tank mounts Tranx transponder mount Renthal soft grips Harris axle & paddock stands Wheel fitting trolley Filler tanks Spare keys, & paperwork, V5 Numberplate & bracket, Horn for daytime MOT, some spare ti bolts. Loads of videos of me out on the bike here, I've manage to get some fairly decent lap times. (there are also vids of my old GSXR750 too so check the description) https://www.youtube.com/user/EllzIS200/videos Bike has been out once this year at Angelsey and performed great, I did a oil and filter change before this track day so it is good to go out again at least for a couple of more days. Front pads will need changing soon. Since I've had it all I have done was change the brake calipers and had the suspension set up (Roughly 15 stone with gear on). This bike can be had with the 16.5 dymag wheels and a stack of tyres to keep you going for a good year or so, or these can be sold separately and the standard 17inch wheels with wets can go on for the sale. Price with the Dymags and tyres is £4500. Edited by ellz - 08 June 2015 at 12:34 |
Dave S
Novices Joined: 20 August 2009 Location: Angus Status: Offline Points: 98 |
GLWS That looks MINT!!!
seddo
fast Group Joined: 12 July 2014 Location: southport Status: Offline Points: 265 |
Hi mate i seen you at anglesey on 5th april i walked in your garage with near enough the same decaled bike haha. Glws mate. Great bikes
ahthud
Instructor Joined: 18 June 2012 Location: kent Status: Offline Points: 1487 |
Sorry for jumping the thread. But what's the B1H linkage conversion about?
Kirklet
fast Group Joined: 14 March 2014 Location: Hull Status: Offline Points: 464 |
Yeh, was going to ask the same question myself, I've got a very similar spec 05 ZX10R.
gixasix
Instructor Joined: 08 December 2013 Location: Surrey Status: Offline Points: 3576 |
That looks a lovely bike for the money. GLWS
quarrybends
Instructor Joined: 08 June 2012 Location: yorkshire Status: Offline Points: 2917 |
More linear innit (common mod in its day) |
Kirklet
Ah right, ahthud, after a little searching I found this.
http://www.zx-10r.net/forum/f28/04-05-zx10r-rear-suspension-mod-16897.html#/forumsite/20704/topics/16897 Expands on what QB said. |
ellz
Cheers for the comments guys.
To be honest I had never really looked in to the rear shock mod. It was already on the bike when I bought it. It does handle very nicely. |
ellz
BTTT
Maddog
Novices Joined: 07 October 2013 Location: Bucks Status: Offline Points: 85 |
Cracking deal for someone! If i had the room id bite your arm off.
Slight hijack but Whats the deal with the data overlay in your youtube vids? Does dashware do it all or do you need additional kit? |
dw22
intermediates Joined: 14 July 2014 Location: Kent Status: Offline Points: 146 |
If i had the cash I would be biting your arm off as well!
Looks mint!!!
ellz
Whoever buys this I'll actually throw in the bluetooth qStarz BT818 GPS logger. Then you can overlay your own data on your videos.
The best app is Racechrono for android.
ellz
On ebay
http://www.ebay.co.uk/itm/111668140592?ssPageName=STRK:MESELX:IT&_trksid=p3984.m1555.l2649
ellz
Still for sale, minus AP racing rear caliper.
ellz
On ebay again.
http://www.ebay.co.uk/itm/-/111728487605?
ellz
SOLD
Post Reply | |
Forum Jump | Forum Permissions You cannot post new topics in this forum You cannot reply to topics in this forum You cannot delete your posts in this forum You cannot edit your posts in this forum You cannot create polls in this forum You cannot vote in polls in this forum |
