  New Posts New Posts RSS Feed - HEL V2 Brake and clutch master cylinders
alboy850 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote alboy850 Quote  Post ReplyReply Direct Link To This Post Topic: HEL V2 Brake and clutch master cylinders
    Posted: 17 May 2025 at 11:30
Just Released by HEL Performance
HEL V2 brake and clutch master cylinders with billet aluminium reservoirs.
These are the new generation of HEL master cylinders.
Clutch  m/c and reservoir brand new. Inc micro switch and all banjo bolts and crush washers.
Brake 19 adjustable ratio  m/c has been used but not for long, the reservoir is brand new. Inc micro switch and all banjo bolts and crush washer.
You dont need to use the billet reservoirs as there is a fitting so you can still use the plastic bottles.
A fantastic upgrade.
Looking for £550 ono inc uk delivery.
will split at £275 each
Any pics required then drop me a message and I can email or watts app etc
This page was generated in 0.064 seconds.
